700r4 to T5 question
Old Mar 12, 2010 | 05:19 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , i have a question about the wiring for the electric trunk switch...i re-wired the back up lights and also the neutral clutch switch,,,but my trunk won't open now anymore with the switch,,my electric windows are fine but that middle switch is not working,,,it's got a brown and orange wire,,,the orange has constant power t,,,the brown has no power key on or off....does this have anything to do with the automatic shifter wires?...thankyou.
Old Mar 12, 2010 | 10:03 PM
mooch1's Avatar
Transmission: T5 WC
Re: 700r4 to T5 question
anyone?
Old Mar 12, 2010 | 10:35 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Did you wire the Neutral Safety Switch through the clutch pedal? It should and then the trunk open switch will work when the clutch pedal is depressed.
Old Mar 13, 2010 | 06:42 AM
mooch1's Avatar
Transmission: T5 WC
hi,,,no i didn't rewire the neutral wires (purple-yellow) through the clutch pedal...i didn't get that switch when i bought all my T5 conversion parts..wasn't there...i have tried calling several autoparts and even gm dealers...all discontinued or not available...thank god for 3rd gen....thanks.
Old Mar 13, 2010 | 10:01 AM
mooch1's Avatar
Transmission: T5 WC
hi, what i did was install a switch from the purple -yellow wires to act like a neutral safety switch like on the clutch pedal...until i can find one for the clutch pedal anyways ....once i push this switch with the key ON the trunk opens!...you really helped me save 2-3 days of headaches...thankyou.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Vojtush31
Oct 11, 2015 01:07 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
apie2546
Sep 20, 2015 01:03 PM
