Popping out of gear
Old Mar 13, 2010 | 01:57 PM
91black5spd's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Transmission: 5 speed Manual
Popping out of gear
I am having a problem with the shifter popping out of gear when the car is cold. It happens with every gear but 1st. When the car warms up it works fine.
I have a 91 firebird with 5.0 TBI L03 and T5 manual tranny. It is basically stock with 56k miles. The only thing I had changed was the shifter to a pro 5.0 I then switched back to my factory shifter about 6 months - 1 year ago. I only drive the car once every month or so. Problem didnt start until i switched back to the stock shifter. So, I was thinking it was a problem with the shifter, but why would it go away if the car warms up? I havent tried switching back to the pro 5.0 but thats what I might try.
Old Mar 13, 2010 | 02:06 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Popping out of gear
Manual transmissions pop out of gear when they don't fully engage the gear. Typically the causes are:
- Mis-adjusted shifter stops
- Worn/Broken shift fork pads
- Worn/Broken shifter offset lever cup
- Worn/Broken synchro keys
Old Mar 15, 2010 | 05:27 PM
Engine: 305 TBI
OK thanks, I will try the shifter first, the pro5.0 has adjustable stops so if I switch to that and its fixed, ill know its the shifter.
db057
Apr 28, 2019 07:45 AM
Fronzizzle
Sep 8, 2015 12:10 PM
toyotekk
Sep 7, 2015 06:36 PM
toyotekk
Sep 6, 2015 02:21 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
