Transmission Hook up. PLEASE HELP!
Old Mar 16, 2010 | 05:45 PM
91_RS_Vert's Avatar
From: Middletown, OH (Between cincinnati and dayton)
Car: 1991 RS Convertible, 1990 RS T-Top
Engine: Camed 355(carbed), LO3 305 TBI
Transmission: B&M Built 700R4, stock 700r4
Axle/Gears: ten bolt posi 3.73s, stock 2.73s LS
hey guys. really need some help here. i have my motor out of my car on the chains on the engine hoist. i have had my transmission completely rebuilt and i am going to hook up the transmission to the motor outside the car and drop it in as one unit. i decided the best way to do it was to install the torque converter to the flywheel and stick the transmission into the torque converter and bolt it up that way. well after about an hour of trying to get it on i have a brand new torque converter with lots and lots of end play now and im screwed. please what would be the best step by step way to hook this trans to this motor so i can take my car off the jack stands its been on for a year now. I have dont a lot harder things than this and its really bugging me that i cant get this done right and my torque converter is screwed up. so somebody please help a 19 year old kid that just wants to drive his car again!! thanks guys!
Old Mar 17, 2010 | 12:55 AM
chrisblazzer89's Avatar
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
Re: Transmission Hook up. PLEASE HELP!
install torque converter into tranny, line up tranny with motor install 2 bolts to hold tranny on engine, then line up flywheel bolt holes with torque converter, tighten converter bolts, install all housing bolts and done
Old Mar 17, 2010 | 10:28 AM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
Install it on the tranny first.
There will be alot of endplay but it should not be more than about a half inch. This is fine.
Old Mar 17, 2010 | 10:40 AM
91_RS_Vert's Avatar
thank u guys i appreciate it. im gonna run down to the trans shop and have em look at my converter to see if shes still ok. if not ill just shell out the money for another one i guess. and to iroc u thanks for your service in iraq and that sounds like a hell of a monster ur buildin. maybe u should just take that over there and scare all of em back in their holes!!!!
Old Mar 17, 2010 | 10:49 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
always install the converter in the trans first, if it's not aligned correctly you will break the pump in the trans. I made this mistake with a TH400 several years ago.
I'd have the trans checked out as well, you won't get far if it's damaged..
Old Mar 18, 2010 | 12:46 AM
91_RS_Vert's Avatar
loaded everything up and went to the trans shop today. everything checked out ill be puttin it together and droppin it all in tomrow. should have got on here before i started cause last time we put the motor in it someone else did this part while i worked on something else. u live and u learn.
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
deracer
Apr 11, 2016 12:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
