700r4 problem HELP!
Old Mar 17, 2010 | 06:02 PM
NubcaekJack's Avatar
Car: 88 Camaro
700r4 problem HELP!
Greetings TGO members, I am in need of some assistance.
When I purchased my 88 Camaro, the P.O. had installed a TH350 into the car. It finally gave up the ghost and I replaced it with a 700r4 that I purchased from a member here on TGO. Everything seemed to go smoothly, but now I cannot get the trans to go into any gear. As in, I have park, and every thing else is neutral. It rolls forward in reverse, backwards in drive, etc. Relevant information: Carb'd SBC 350, no computer/ECU, B&M Megashifter. If there is any other information I am missing, please let me know so I can get this all figured out. Thanks in advance!
Edit to add: I have also adjusted the shift cable and tried putting the trans in gear with the selector by hand.
Eagerly awaiting your replies.
-Steve
Last edited by NubcaekJack; Mar 17, 2010 at 06:18 PM. Reason: Added more information.
Old Mar 17, 2010 | 08:52 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: 700r4 problem HELP!
Fluid level ok
Old Mar 18, 2010 | 11:12 AM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
hey, when you took the torque converter out and then re installed it im pretty sure you did not have it all the way in and when you installed the transmission you broke the pump due to the converter not being all the way in.......so the converter was forced on the pump .............
Old Mar 18, 2010 | 11:33 AM
91V6firechicken's Avatar
when you put the TC in was the little nose on the TC about even with the bellhousing or was it sticking out a little further..... other then that i would check the fluid levels.....
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
