Swapping in a 98 rear end
Old Mar 17, 2010 | 09:55 PM
sethteef's Avatar
Car: 88 firebird
I read that the rear end bolts right up with the drivetrain but I wanted to make sure there wasnt anything else that needs done. I found a 98 rear end out of a firebird that has posi, disk brakes w/ cross drilled/slotted rotors for 250 and was gonna jump on it.
Old Mar 17, 2010 | 11:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Swapping in a 98 rear end
If you do a you'll see that the biggest issue is the e-brake cable - there are several ways to attack it, you'll see them all with some research.
Some swap out the proportioning valve to accomodate for a different fluid pressure requirement of the rear disk vs. drum, some say leaving the stock valve works fine.
Depending on your car, might have to remove and use the brake hardline and T fitting from your 3rd gen rear - some of the 4th gen rears had different sized fittings between the car and the axle.
That's about it.
Old Mar 17, 2010 | 11:14 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
the diff is 2 inches wider...your tires will stick out more..
Old Mar 17, 2010 | 11:23 PM
sethteef's Avatar
Car: 88 firebird
Well thanks for the input and I do some searching before I posted another thread on this. The old threads say that with the 4th gen rear end my tires will be more or less flush with the fender. I didnt see the problem about the e-brake though I guess I over looked it. So let me ask this is a good buy? My rear-end has a worn out posi-unit and leaks. I also wanted a different set of gears and I wanted to get disks all around.
Old Mar 17, 2010 | 11:34 PM
Stephen's Avatar
Car: 87 GTA
16" wheels = flush
15" wheels....I've never looked at the backspacing
The 2 e-brake cables can be spliced together, or, I believe it is, Hawk's make a new one with 3rd gen on one end & 4th gen on the other.
Old Mar 17, 2010 | 11:37 PM
sethteef's Avatar
Car: 88 firebird
I have 17x8 rims not stock
Old Mar 17, 2010 | 11:42 PM
sethteef's Avatar
Car: 88 firebird
Also on some of the old threads they said you could buy a new 3rd gen cable the longer of the two lengths and that all was well??
Stephen's Avatar
Car: 87 GTA
Depends on your backspacing then.
My 17" x 9" (before I had them widened to 11") had 5" bs & were in maybe .5", on my stock 9-bolt axle.
So on mine, 2" wider would push them out about 1.5", past the fenders.
Old Mar 17, 2010 | 11:47 PM
sethteef's Avatar
Car: 88 firebird
It wouldnt bother me if they stuck out a lil bit. If i had know that you could swap rear ends and get widers rims I would have done that the first time. So eventually I would get a pair of 17 or 18x9 or 9.5 for the back. Do you think it is something I should invest in?
Old Mar 18, 2010 | 12:08 AM
Stephen's Avatar
Car: 87 GTA
1.5" out PAST THE FENDER, is not "stuck out a little bit". You could stand on top of that tire, beside the fender!
And I'm confused. You just said a few posts ago:
On a 4th gen rear end, whatever wheels you have or get...You'll need wheels with the modern offsets like the 4th gen & C4/C5/C6 wheels.
Old Mar 18, 2010 | 12:18 AM
sethteef's Avatar
Car: 88 firebird
Sorry about that I was confused myself. I understand what I would need for the tires. I didnt realize the offset differences, or that I would need that 4th gen rear end stuff. I tend to over look things. Anyways they didnt sell that size for the 3rd gen but i think they did for the 4th gen. If its not a good idea I'll just buy the cowl hood I was planning on since I will need clearance for the engine I have planned.
Also I am pretty sure but not postive that the tires have the backspacing as the 16x8 tires i took off.
Old Mar 18, 2010 | 07:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Ed Miller makes custom parking brake cables for the LS1 (98+):
http://www.flynbye.com/catalog/i153.html
Aside from the parking brake issues, you'll have to consider the combination valve and speedo gears. The following link may provide food for thought:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 18, 2010 | 11:04 AM
sethteef's Avatar
Car: 88 firebird
I know that if the rear end gears are change the speedo wont register correctly. I did already see that the valve should be replaced but could work with the stock one.
Old Mar 18, 2010 | 11:59 AM
JamesC's Avatar
While the drum/disc combination valve will work, remember that GM designed three valves--disc/drum, disc/disc, and 1LE, each I believe with increased bias--so the correct valve for your application is a wise choice, IMO.
JamesC
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
