deep or finned pan?
Old Mar 17, 2010 | 03:42 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
deep or finned pan?
i have a turbo 350 and i was looking at deep and finned pans, i want one with both but right now i dont have the money for both so i want to know what would be better. i can get one with 3 qt extra capacity or i can get a stock depth pan with fins. which would be better? thanks Ty.
Old Mar 18, 2010 | 03:03 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Re: deep or finned pan?
I'd just do a transcooler so you by pass the radiator, and there cheap. Otherwise Deep or finned eirther one will run with what the radiator temp is.
Old Mar 19, 2010 | 07:04 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Get a good aftermarket cooler. If you search around on here about deep pans, almost everyone has had problems with them scraping the ground in camaros.
Old Mar 19, 2010 | 04:16 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Deep pans equal problems and fined pans are aluminum and they are worse yet...they don't bend but crack. So take your choice of what you want and either are good choices.
Old Mar 19, 2010 | 06:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I ran a chromed pan on my glide for years. I finally installed an aluminum deep pan (with fins). The extra capacity helps in cooling the oil even though I still run a huge cooler and the aluminum pan adds rigidity to the transmission case.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
