tourqe converter help
Old Mar 18, 2010 | 05:18 PM
DVR408 88 iroc's Avatar
Car: 88 iroc
Engine: 5.7 TPI
Transmission: TCI Street fighter
What size stall converter should i use for my engine? i have a 5.7 liter tpi and i just put in a new tci transmission with a 2000 stall torque converter but it is slower than my original
Old Mar 21, 2010 | 03:41 AM
Pat Hall's Avatar
Re: tourqe converter help
If your motor is all stock a 2K converter should work really well. I'm willing to bet your TV cable probably isn't adjusted right. It it's not set right it throws off the shift points, takeoff ability, basically everything. If you're sure the TV is set properly then it could be an issue with the governor calibration. Unless the converter is messed up somehow, the 2K stall speed should be about just right.
Old Mar 23, 2010 | 10:04 PM
Car: 88 iroc
Engine: 5.7 TPI
ok..the tv cable is wat connects to the rear of the tranny for the speednometer gear?
Old Mar 23, 2010 | 10:26 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
No, thats the speedometer cable. The TV cable is what attaches to your throttle linkage on the throttle body and then runs down to the passenger side of the transmission. It attaches right next to where the dipstick goes in the trans. Adjusting it just a little will have a big impact on the way the trans acts.
Old Mar 23, 2010 | 11:01 PM
Car: 88 iroc
Engine: 5.7 TPI
oh ok im hoping and thinkin thats the problem...thanks man.. i also like the way u have your z28 set up
Old Mar 24, 2010 | 03:38 AM
Pat Hall's Avatar
Yeah it's absolutely crucial that you get it adjusted right. It affects both the shift points and how much line, or internal pressure you have in the transmission. If your line pressure is too low you can easily burn up the clutches in your trans. Do a search here on the boards for adjusting the TV cable and you'll find tons of info on how to get it set right.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
