questions on rear end
Car: 89 IROC-Z
Engine: 350 tpi
My rear blew out on my car it was a 10 bolt posi disc.
Two questions:
1) If i buy a rear can i just use the middle section i.e. differential and gears?
2) If i bought a drum posi rear can i take the drums off and put on my disc setup
Thanks in advance for the help,
-Danny
Two questions:
-Danny
Re: questions on rear end
Two questions:
-Danny
Two questions:
-Danny
2) yes, if the disc backing plates will fit.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
In order:
1 - It depends on how much damage was done to the housing when it went, and what you get the center section out of. You can use one out of any 3rd or 4th gen F-body or one out of an 82-97 S10/S15/Blazer/Jimmy. Possibly a few others, but those are the ones I know for sure will work.
2 - Yes, as long as both are F-body rears its a pretty straightforward swap.
EDIT:
DJP87Z28 is correct, the axle spline count must be the same, I forgot about that. Or you could swap matching axles too.
EDIT:
The 7.5 10 bolt uses a 2 series differential for 3.08 to 2.41 gears and a 3 series for 3.23 to 4.10 gears. You must use the right series for the gears. There are 26 and 28 spline axles. You must use the right differential for the axles that you have. You can not simply unbolt the internal parts from one rear end and bolt thenm into another housing. You MUST set the pinion depth, bearing preload and backlash whenever you change parts from one housing to another.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Car: 89 IROC-Z
Engine: 350 tpi
Nothing moves....it is a complete unit. Pull the axle shafts, remove dr shaft and remove 10 diff caarier bolts to the axle housing. So what do you need to set up?????
Car: 1992 Camaro RS
If you swap the whole center section, the only thing you don't have to to worry about is if the gears will fit the carrier if you use the everything from the same axle. If the OP is talking about just swapping the carrier over to his ring & pinion then he will definitely need to make sure the carrier fits the ring gear.
EDIT: Its also a good idea to change the bearings on the carrier when you swap it. It really sucks pulling something back apart 2 months after you put it in just to fix something you could have done the first time. Plus, they will probably be worn to the axles they originally came with, not his axles.
I don't know if I'm not understanding you or if you are not understanding me. Are you talking about changing the complete rear end or the internal parts? If you are talking abouot swapping the complete rear end then there is nothing to set up. If you are talking about removing the ring & pinion gears and differential then the pinion depth, bearing preload and backlash MUST be set again. You are talking about things that are set to +/- .001 inch and there is much more than that amount of machining tollerances between each housing.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
