another transmission fluid question...
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, do you think that Castrol DEX/MERC transmission oil is safe to use in the 700r4 in my 1991 trans am? the label says "for older GM and ford vehicles."
Re: another transmission fluid question...
Should be ok to use. I bought the cheapie Coastal brand from Vato Zone, and it says the same thing on the label, "Dex/Merc". I think the only GM trannys it probably isn't recommended for is the brand new ones that call for the new Dex IV stuff.
Engine: LB9
Cool thanks! I only need to add a little bit (half a pint tops probably) since I lost some transmission fluid when I removed the radiator (trans. cooler lines).
Engine: LB9
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Numbah-1
Sep 12, 2015 08:57 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
