Bell housing and fly wheel questions please needing help
Old Mar 23, 2010 | 09:41 AM
Kurtis2short's Avatar
Alright I have a 88 firebird with a 402 chevy big block with a beefed up t5 and I'm running the Lakewood bell housing for the 82-92 fbody so I could run a 11.5 clutch and flywheel I bought it off eBay at the time it said t 56 would bolt to it so now I have a 95 t56 from a lt1 I wanna put it a boom bolt pattern doesn't exist for it I'm told I could use a lt1 bell housing but I'd have to get a custom made flywheel and switch it to a pull style does anyone know whom would make one or do u guys think I should drill and Tap the Lakewood bell housing has anyone ever done this cause I really don't wanna shell out 500 for another bell housing or does anyone know of a kit for this
Old Mar 23, 2010 | 10:02 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Bell housing and fly wheel questions please needing help
The LT1 T56 will require a special conversion flywheel and it' own sized bellhousing. A LS1 T56 can be used with an adapter plate ($200) and use your existing T5 clutch/bell/linkage, you just need an extended pilot bushing.
You have several options, you just need to figure out which path you prefer or can afford, then go from there..
http://www.sallee-chevrolet.com/Borg.../bwt56pics.cfm
http://www.thegearbox.org/catalog/it...17/4803441.htm
Old Mar 23, 2010 | 12:32 PM
Do u know the name of the site or company that makes the adpater plate for the ls1 I'll just sell one I have and buy one for the ls1
Old Mar 23, 2010 | 12:40 PM
85MikeTPI's Avatar
Follow the "thegearbox" link I posted above and it'll take you right to it..
In addition, If you have the means you can pull off the front plate from the LT1-T56 and just swap in a LS1 input shaft, reshim it, and sawsall off the TOB guide tube. The adapter plate will then work the same.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZ1989
Jan 24, 2016 03:55 PM
milk
Aug 10, 2015 06:26 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
