91 formula with 87 bw 9bolt rear help with wheel seals
Subscribe
Mar 24, 2010 | 09:58 AM
hello,
I have a 91 formula (305e) with a borg warner 9bolt from a 87 ta, it has discs, the passenger side wheel seal is leaking, how do I remove the axle to get this wheel seal replaced?
I have heard tha t 9 bolts dont have C clips like 10 bolts do. is there anything special that I need to do or just unbolt the wheel and caliper bracket and pull? do i need to remove the bearing from the axle or is it pressed into the tube? any help would be appreciated, ive searched here and all over google but no real steps for the 9 bolt , all c clip stuff.
thanks!!!
Reply 0
Mar 24, 2010 | 10:06 AM
Re: 91 formula with 87 bw 9bolt rear help with wheel seals
i may have posted this in the wrong forum
Reply 0
Subscribe
