what rear is this? will it fit?
Old Mar 26, 2010 | 09:02 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
Got a rear here. (found a 10 bolt in my 87 350 iroc, kinda pissed) its supposed to have a 9 bolt BW.
have this in the shop on the floor from a different car, was said to be out of a buick fron the 70's?
dont know what it is other than its 411 gears.
Old Mar 26, 2010 | 09:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: what rear is this? will it fit?
No it won't fit.
Trying to swap the entire diff over will be very difficult. Providing it's even close to the same width, there's no easy way to attach the torque arm.
GM produced 3 different 10 bolt diffs. 7.5/7.625, 8.2 and 8.5". Nothing between these 3 diffs is interchangeable.
Old Mar 26, 2010 | 11:16 PM
Car: IROC Z
Engine: 5.7
ah i knew there was somthing missing on it
Old Mar 26, 2010 | 11:23 PM
Stephen's Avatar
Car: 87 GTA
No different than putting in a OEM Ford 9" & having to fabricate a torque arm bracket, make LCA & spring mounts.
So while it isn't real easy. It isn't anything new either.
Old Mar 26, 2010 | 11:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Nothing is impossible and with enough time, money and fabrication skills, anything can be accomplished. For things like the diff swap, it can be a whole lot easier to just buy an aftermarket direct bolt in diff and chances are it will end up being cheaper and safer.
Old Mar 27, 2010 | 07:03 AM
big gear head's Avatar
It's an 8.5 10 bolt with a Traction Lock differential,. The right bearing cap (left in the picture because it's upside down) is on backwards. I can't tell exactly what it came out of without measuring it. It actually looks more like a '71 or '72 A body rear end. I know some Chevelle guys who would like to have it.
Old Mar 27, 2010 | 12:30 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello 85berlinetta2.8!!
Maybe I have your 9 bolt BW, I found a 9 bolt BW 3.27 from a 350, when I should have had a 9 bolt BW 3.45 in my 1987 IROC TPI 5 speed 305!!
My car was bought in Ontario!!
customblackbird
Aug 15, 2021 10:16 PM
I'llrocya
Feb 2, 2016 11:43 PM
hectre13
Aug 26, 2015 08:17 AM
z28addict8490
Aug 7, 2015 08:48 PM
