th350 final assembly
Old Mar 27, 2010 | 01:44 AM
j_camaro_67's Avatar
Car: dark hunter red 84 camaro
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
i am finishing up my th350 build and would like to know if its safe to use white grease on the bearings, seals, and bushings. i would like to get it together tomorrow, thanks jason
Old Mar 27, 2010 | 04:56 PM
hotshotcamaro's Avatar
Car: 89 camaro RS
Re: th350 final assembly
i am no expert, however if you are using white lithium grease that can safely be put on almost anything i use it at work on distributor bearings all the time (which is not going to make sense to most people, because i work on large engines) but it should not be a problem for you
Old Mar 28, 2010 | 12:17 PM
rayar's Avatar
Car: 83 Camaro
Engine: 4 Bolt 350, Bowtie aluminum heads
Transmission: TH350
Axle/Gears: 3.42, superior axles, Torsen diff
many parts stores carry a lubricant called trans goop. I have also heard that vasiline will also work, I just wouldn't overuse it.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Dragonsys
Sep 25, 2015 03:51 PM
