what rear gears are you guys running with a th350/th400?
im going to swap one of those in my third gen but need rear gears to go with it, what are you guys running and how do they perform off the line and at high speeds?
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: what rear gears are you guys running with a th350/th400?
i have 4.85:1 running 1.60 60ft. what are you using the car for?
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
run 4.56's 4.10's 3.73's 3.23's 3.08's you name it I have ran it with a th-350
running 4.10's right now in the race car and 60's in 1.4's
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
The intended purpose of the car is going to make all the difference in the world as far as what gear you should run. My car is a fun weekend street car and I have a 3.50 gear. I think its a good street gear if you dont do a lot of highway driving. At 70 your going to be at about 3200 rpms with a stock height tire. The car can get to about 130 with stock height tires at 6000 rpm's.
hectre13
Dec 11, 2023 08:14 AM
