GM 10 Bolt question
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
GM 10 Bolt question
I recently got a a new ten bolt done up and am installing it in the car next week. I need to redo the brake lines as currently there are none on it. What I need to know is how they are mounted and where they end for the flex lines. If you have any pics that would be cool. Thanks
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: GM 10 Bolt question
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
EDIT: The lines for either, I believe, are available from http://www.finelinesinc.com/ or one of the other after market providers.
JamesC
Car: 89 IROC
I didnt get the link to the posts that yuo where talking about. I will be making my own brake lines and yeah I forgot to say it was for disc brakes. I have the old iron ones from the earlier years. Is that the ones you called Delco-Moraine calipers???
JamesC
Car: 89 IROC
I have a set of earls flex lines for both sides will that be a problem at all and no I go to find the clips for where the hard line meets the flex line or I will have to make my own. The fun never ends
http://www.andyz28.com/3rdGen/reardisc.html
JamesC
Car: 89 IROC
The Delco-Moraine's only have a single flex line to the pass side as I mentioned above, but if you're fabbing your own lines, I suppose you could somehow use both Earl's pieces. The following site has the clips for both sides, but they may be part of a kit:
JamesC
JamesC
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
