posi traction
Old Mar 30, 2010 | 03:27 AM
PT3BOOMER's Avatar
Car: 84 Z28 / 99 S-10 ZR2 4X4
Engine: STOCK CARB'D 305 WITH 350 HEADS
Axle/Gears: STOCK
posi traction
hey guys, when i burnout, the passenger side wheel is the only one turning. how do i get them both turn without swapping the whole rearend. can change the gears inside or something? or clutch packs??? what are they?
Old Mar 30, 2010 | 06:22 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: posi traction
First check your RPO codes for G80 (Limited Slip rear) if you do not find this code you have what is called a "Open rear". Posi-traction is a old term used by Chevrolet Div in the 60's for a limited slip rear. You can buy a LIMITED SLIP carrier or replace the whole rear. Whichever way, it is going to be expensive ($500+ range) just to do burmouts. Which by the way are not a good way to treat mechanical parts
Old Mar 30, 2010 | 06:33 AM
PT3BOOMER's Avatar
Axle/Gears: STOCK
Re: posi traction
no its not just to do burnouts, i just notice when i take off, that wheel spins more. whats a rpo code? g80????
Old Mar 30, 2010 | 06:43 AM
DJP87Z28's Avatar
Re: posi traction
Read previous Post again......
Old Mar 30, 2010 | 09:07 AM
big gear head's Avatar
Re: posi traction
Dod your car come with a limited slip differential (posi)? If it did then it will have RPO code G80. This is the ecode for the LSD. The codes are on a white decal usually on the bottom of the console lid. They are 3 digit codes and will tell you everything about the car.
If you had G80 and it no longer works then that means you had an Auburn and it is now worn out. You can not rebuild an Auburn. If you have 3.23 to 3.73 gears then I recommend replacing the Auburn with a new Eaton Posi. The Eaton is much better than the Auburn. This will tell you what needs to be done to install it. http://www.nastyz28.com/forum/showth...t=install+posi
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
