t5 swap (vss)question
Subscribe
Apr 2, 2010 | 05:43 PM
im swapping t5 from 88 formula into my 88 camaro . the speedo sensor on the t5 is for the electric speedo .mine is mechanical .ive switched auto trans before with the same cercumstances . but the speed sensor on this t5 doesnt look like i can just switch it with the gear driven one .was there a different tail houseing on the camaro t5s with the mechanical speedo gear?
Reply 0
Apr 2, 2010 | 11:43 PM
Re: t5 swap (vss)question
http://www.thegearbox.org/catalog/it...17/7084167.htm
Reply 0
Apr 3, 2010 | 06:40 AM
Quote: im swapping t5 from 88 formula into my 88 camaro . the speedo sensor on the t5 is for the electric speedo .mine is mechanical .ive switched auto trans before with the same cercumstances . but the speed sensor on this t5 doesnt look like i can just switch it with the gear driven one .was there a different tail houseing on the camaro t5s with the mechanical speedo gear?
T-5 to T-5 should be a direct swap.
JamesC
Reply 0
Subscribe
