2 questions..slipping transmission, and lots of oil loss..
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
what would cause my transmission to slip, ONLY in drive? i have a b&m shifter in my automatic 305. If i drive it the way the B&m was made for (1st...shift, 2nd...shift...3rd...shift...overdrive) then it seems ok. My shift **** broke off...yes, BROKE right off. so I have been just putting it in drive and driving it like an automatic. and usually once it shifts into second, after a few seconds it slips and acts like its in neutral until i let off the gas for a few seconds. I have also been noticing rapid oil loss. I haven't seen any spots under my car, so I'm guessing its burning off. But why? and yes, i have tried driving it after filling up my oil and it still slips. but like i said. it only does it in drive. any help?
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 2 questions..slipping transmission, and lots of oil loss..
the forward clutch is engaged in all forward gears. overrun clutch is engaged in all forward ranges except OD. forward sprag is holding in 1,2, &3. 2-4 band is holding in 2nd and 4th. maybe this can help you diagnose your problem. see if you have tranny fliud in the radiator
Engine: 305 v8
ok, thank you ill check that out tomorrow after work...but how can i tell if there is tranny fluid in my radiator? just look in with a flashlight?
ambainb
Apr 25, 2016 09:21 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Navy8125
Aug 21, 2015 09:32 AM
