in need of a rear end....
Old Apr 6, 2010 | 06:24 AM
overboost07's Avatar
Car: 1988 pontiac trans am gta
Engine: 305 tpi
Axle/Gears: factory
just like the title says i need a posi rear end for my 88 gta
Old Apr 6, 2010 | 07:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: in need of a rear end....
You might consider posting the TGO's classifieds, which will no doubt get you better responses.
JamesC
Old Apr 6, 2010 | 07:26 AM
Engine: 305 tpi
Axle/Gears: factory
JamesC
will do, thanks james
Old Apr 6, 2010 | 07:27 AM
big gear head's Avatar
What power level? Do you want a OEM rear end or after market? The original rear ends were the 7.5 10 bolt and the Borg Warner 9 bolt. Neither one is a great rear end and will not hold up to large amounts of power. If you only have 350 HP then one if these would probably be all right for most use. If you have much more than that then you need to look at a Moser 12 bolt or something similar.
Old Apr 6, 2010 | 07:31 AM
Engine: 305 tpi
Axle/Gears: factory
mine is a stock 305 tpi, just looking for an oem diff basically
Old Apr 8, 2010 | 02:32 AM
Engine: 305 tpi
Axle/Gears: factory
ttt
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
