So im actually considering it
Old Apr 6, 2010 | 11:34 PM
rdsxfn524's Avatar
Ford 9 inch with 3.73 is there any downfall and how hard is it to mount
Old Apr 7, 2010 | 07:55 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: So im actually considering it
I have one. Just buy one from Moser. It bolts right in so its a piece of cake. The only downfall, if you can call it that, is that they rob a tad more power than a 10 bolt. But not having to worry about breaking the rear is worth it. I got mine with big ford ends on it and have a wilwood brake kit out back. It is a little over $600 I believe for the brakes. They may be able to make it though so you can use factory brakes.
Do you have the power to need a 9"? Or are you planning on real sticky tires at the track?
Old Apr 7, 2010 | 10:15 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have a Moser and the only downfall that I see is that it's so heavy. It bolts in just like the 10 bolt but if you run a 4" exhaust it'll have to be moved over slightly to clear the third member.
Old Apr 7, 2010 | 10:31 PM
built91Z28's Avatar
Lol, yes they are heavy. I had only ordered the housing and axle package from Moser and when I picked up the box I had sworn they sent me a complete axle
