T5 hydralic line help
Old Apr 8, 2010 | 03:22 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
How do u get the roll pin out of the clutch master cylinder??I am upgrading to one of the braided steel lines from member Apache.Do i need to remove the master cylinder or is there a trick to getting it out?
Old Apr 9, 2010 | 11:08 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T5 hydralic line help
Try removing the 2 nuts inside, pulling the u-bolt out and rotating it. Might work.
Old Apr 9, 2010 | 11:34 AM
howy03's Avatar
thanks buy the looks of it I will probably have to pull it.Also loos like i may have to pull the booster,pain in the a##
Old Apr 9, 2010 | 01:24 PM
jmd's Avatar
jmd
Booster can stay. Just make sure it's unclipped from the clutch pedal and that u-bolt is out.
Old Apr 12, 2010 | 06:26 PM
macurtis's Avatar
Car: 1986 Z28 camaro
Engine: 350 bored .60 over
Transmission: t5
Axle/Gears: GM posi with 3.73 gears
booster can definately stay, done mine couple times now.....line keeps breaking, where did you find a replacement steel braided line? thank you
Old Apr 12, 2010 | 06:34 PM
howy03's Avatar
do a search for posts by tgo member apache.He may still have some they are real nice.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
