Transmission rattles?
Old Apr 12, 2010 | 11:43 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
I got a stock 91 firebird with a automatic trans. So im sure it has a 700r4 in it. when i accelerate i hear a rattleing noise coming from underneath the car. It dont sound like grinding just rattleing. And when i press on the gass peddel my RPM's stay low; low as in when i iv never seen it get over 4000RPM. when im just cruising at 40mph it stays at 1100rpm. Is it that my trans is going out?
Old Apr 12, 2010 | 12:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Transmission rattles?
I've never heard of a tranny making a rattling noise - lots of other noises, but never a rattling.
I'd check other sources - like loose exhaust first.
And I'd readjust the TV cable might solve the low rpm issue.
Old Apr 12, 2010 | 02:42 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Its probably your transmission mount broken.
Old Apr 12, 2010 | 05:18 PM
Pocket's Avatar
Car: 91 Trans Am
Pumps will rattle when they go out. The trans would be acting all sorts of screwy in that case
More often, the converter bolts get loose and allow the TC to rattle against the flexplate. Drop the dust cover and see if all 3 are tight. Use a bit of locktite on them for future peace of mind
A bad trans mount will allow the tailhousing to bang into the floorpan under accelleration. His rattle is at low speed cruise, so thats out. If its more than a few years old it wouldnt hurt to replace it though. +/- $5 They do wear out quickly
Cats rattle when they clog up and pieces break free. When you're under inspecting the converter bolts bang on the cat with your fist or a rubber mallet
Another common rattle is the cat heat shield on the floor pan. Its held in with a handful of selftapping screws and overtime they fall out allowing the sheetmetal to touch the exhaust
Old Apr 12, 2010 | 05:41 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
to a glance, the shield above the cat is kinda tore up looking. The tailhousing does hit the car when i press it hard and the rattle only happens when i accelerate, not at a low cruise.
Also what what pumps are there to a transmission?
Old Apr 12, 2010 | 05:43 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Sorry im kinda retarted from hitting my head alot in high school fotball
Whats the TV Cable and how would i adjust it?
Old Apr 12, 2010 | 05:47 PM
Pocket's Avatar
Car: 91 Trans Am
Trans main pump is driven by the converter. Sort of like the oil pump on your engine
Grab a new trans mount and reattach the heat shield
TV cable controls line pressure in the trans based on how much throttle you're giving the engine. If its out of adjustment your shifts will be early/late/hard/soft and the trans may feel like its slipping. Running it like this for extended periods WILL burn up the trans. Dont adjust the cable unless you need to. If its shifting fine before, leave it alone
Old Apr 12, 2010 | 08:15 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
How would i come to find the trans main pump? i wanna see how it's working.
well my trans has a soft shift and it's always late.
could you instruct me on how to adjust it to the proper manner? to where the rpm's are correct and it's not so late at shifting?
Old Apr 12, 2010 | 08:25 PM
Car: 1992 RS
Engine: Carbed 350
https://www.thirdgen.org/detent
Old Apr 12, 2010 | 08:33 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
thanks ill try it once it's day time
Old Apr 12, 2010 | 09:30 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
I had a similar sound in my Suburban. Found some loose bolts for the flex plate. Just a thought.
Old May 4, 2010 | 11:40 AM
TeddyBizz's Avatar
hey man, did you ever find out what it was? I'm having the same rattle under acceleration. I did find that my tranny mount was broken. I'm replacing it in the morning. The rattle seems to happen mostly around 500 to 1500 rpm especially when the motor is under load, like leaving a light on a slight grade under light acceleration.
Old May 4, 2010 | 11:42 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
check the header to exhuast clamps/connectors..always come loose on my bird.
Old May 6, 2010 | 07:15 AM
TeddyBizz's Avatar
thanks for the suggestion. I'll definitely check that today. Now that I think about it, it does kind of have that kind of a sound to it.
Old Jun 6, 2010 | 07:17 PM
cmm7v3's Avatar
Car: 92 Camaro RS
Engine: 1JZ-GTE
Transmission: R154
did you ever find out what was causing this noise, the same thing is happening with my 92 rs right now
Old Jun 7, 2010 | 07:17 AM
TeddyBizz's Avatar
yeah i did. I did have a BUNCH broken clamps or rusted out clamps on my exhaust. But I also had both my engine mounts broken, transmission mount broken, both universal joints broken, and rear end links broken. So eight hours later, no more rattle. But if I had to choose one thing that Itruly believed was causing the rattle, I would say exhaust.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
GouldyGTR
Sep 7, 2015 09:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
