rear end gearsize
Old Apr 14, 2010 | 10:14 AM
rigbyscamaro89's Avatar
Car: 84 Z28, 89 RS
Engine: 305 ho carb,305 tbi
Transmission: T400, 700R
rear end gearsize
i have 2 camaros and my project is an 89 rs i was thinking about swapping axels with my 84 ho 305 as i heard that they have better axels. I was told the gears in the 89 were the weak gears also put into the S10 of that year. does anyone have any insight on this and what i should do. the project motor to put in the 89 will either be a 350 or 383 with around 400 hp/400tq if this hels any.
Old Apr 14, 2010 | 10:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end gearsize
Welcome to TGO. Both the 84 and the 89 may well have the same 26-spline axles. The info in the link below should provide some useful info:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 14, 2010 | 11:09 AM
Car: 84 Z28, 89 RS
so would i need to upgrade to like a 4.10 if i have a 3.73 or only if i have like a 3.23?
Old Apr 14, 2010 | 05:00 PM
big gear head's Avatar
The S10 and the 3rd gen Camaro got the same gears every year. There is no difference in a S10 gear and a 3rd gen Camaro gear. You probably have 26 spline axles in both rear ends, but you can pull an axle out of the '89 and check it. There is a chance that it has 28 spline axles.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
