Hydraulic clutch fuid
Old Apr 18, 2010 | 03:50 AM
camaro88ukraine's Avatar
Car: Camaro 1988
Engine: 305, carb. 600cfm double pumper
Tell me please which hydraulic clutch fluid i can use instead of GM 12345347 ?
Manual say Dot 3 but i can find only dot 4 and higher. Also i see that old dot3 was mineral and new ones are thyntetic (for example "Motul" Dot3)
Wich fluid and which manufacturer do you use?
also i know that GM 12345347 contain friction modifiers
ps sorry for bad english
Old Apr 18, 2010 | 12:54 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Hydraulic clutch fuid
i use dot 4 brake fluid and havent had any problems. the manual says dot 3 because there wasnt dot 4 when it was written.
Old Apr 18, 2010 | 03:09 PM
Car: Camaro 1988
Thanks for the answer.
look what i've found about friction modifiers which some manufacturers of dot4 may contain and some of them may not:
quote:
(Q.) Do you have any detailed instructions relative to the "PROPER" way to R&R the Clutch hydraulic fluid for a 1984 Vet? A local shop replaced the Clutch Fluid (DOT 3) - before they did the R&R, the clutch worked great (30K original miles). But when I drove away from the shop, the clutch seemed different, and produced gear-clash when I tried to get into reverse. I let the car sit for the weekend, and a few days later the clutch had lost all of it's pressure and shifting the manual transmission was very difficult. I took it back to them and suggested that there was air in slave, and gave them instructions to tilt the slave Cylinder at 90* when bleeding because of the bleeder valve location -they did it, and the clutch pressure came back, could shift into the 4 gears and occasionally ground when going into reverse. I drove the car for 32 miles, and I lost 85% of the clutch pressure, and was unable to shift into any gear. Mike – C4 Corvette owner
(A.) Service (R&R) of the clutch hydraulic fluid for the '84-'88 Corvette is generally the same as the '89 - '91 C4 procedure. The procedure can be viewed at http://www.zfdoc.com/clutch_hydraulic.htm. Remember that DOT3 is a classification of fluid type and does not necessarily contain the additives found in GM P/N 12345347 "Hydraulic Clutch Fluid". For Clutch hydraulic Systems, we actually recommend using Valvoline full-synthetic Dot3/Dot4 Brake Fluid over any other fluid.
http://www.zfdoc.com/faq.htm
Old May 1, 2010 | 10:20 PM
84elco231's Avatar
After flushing clutch slave and lines from repair/rebuild, I use ATF for clutch hydraulic circuit.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
