What gear oil for powertrax no slip
Old Apr 18, 2010 | 12:31 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I lost the instructions for the install and wondering if anyone knows what gear oil to use with the powertrax no slip locker ?
Old Apr 18, 2010 | 12:51 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: What gear oil for powertrax no slip
pretty much any appropriate gear oil will be fine, as long as it has the additive for the non slip. personally i use royal purple. my posi wasnt working when i bought the car and i just thought it was fried, until i started using royal purple gear oil. now it works like a dream.
Old Apr 18, 2010 | 01:11 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Well theres 75w-140 and 80w-90. I'm leaning towards the 75w-140
Old Apr 18, 2010 | 01:45 PM
travis401's Avatar
Car: 91 Camaro RS
i use 75w90
Old Apr 18, 2010 | 01:48 PM
big gear head's Avatar
I put 75W140 Amsoil in mine to try to reduce the noise. It also helps with the towing that I do. This is in my S10 4X4.
Old Apr 18, 2010 | 01:54 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I found the install guide online.
http://www.richmondgear.com/0002pdfs/8221022A.pdf
It calls for 75w140 so thats what i'm going with. Was going to use royal purple gear oil. Is it worth it or just alot of hype ?
Old Apr 18, 2010 | 02:20 PM
travis401's Avatar
Car: 91 Camaro RS
ive seen a lot of car shows on tv do actual dyno testing with royal purple(usually just engine oil) and they always see an increase of a couple horses over other brands. i swapped all my fluids over (engine oil, trans fluid, and gear oil) and i noticed a difference.
maroe624
Apr 16, 2017 08:29 AM
someone972
Aug 30, 2015 12:52 AM
Navy8125
Aug 21, 2015 09:32 AM
