How do I tell if my car had posi?
Old Apr 25, 2010 | 10:03 PM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
How do I tell if my car had posi originally and is worn out or if it just didn't have it. The car used to have a 5.0 HO from the factory.
Old Apr 25, 2010 | 10:27 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: How do I tell if my car had posi?
place a jack under the center of your DIFF.. raise both wheel off the ground...
put the car in neutral rotate one tire if it's POSI both wheel will turn in the same direction.. if it's a open DIFF.. they will turn in opposite directions..
do you have the RPO codes inside of the console ???
Old Apr 25, 2010 | 10:31 PM
Well I've done that. My question is how do I tell if its worn out or if it just never had it. Yes I have the RPO codes
Old Apr 25, 2010 | 10:38 PM
88gta3508's Avatar
Engine: 231 / 383
look for G80
http://www.marshu.com/ws6-firebird-c...codes-2000.php
it's fun to decode what was installed in you car...
Old Apr 25, 2010 | 10:51 PM
88gta3508's Avatar
Engine: 231 / 383
to check it's function.. in park one wheel on the ground one wheel off
use a torque wrench set to 48LBS this would be normal when the wheel spins
if it's less the 48 your cone is worn
Old Apr 25, 2010 | 10:56 PM
88gta3508's Avatar
Engine: 231 / 383
what was the result when you did this
Old Apr 26, 2010 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Pop the cove and take a peek. The following from the 10-Bolt FAQ:
Do I Have a Limited Slip (aka Posi) (RPO G80*)?
Jerk the diff cover.** Open/Standard can be seen in the following link: https://www.thirdgen.org/forums/tr...1073-posi.html (posi?)
Gov-loc: https://www.thirdgen.org/forums/tr...rear-diff.html (3rd gen rear diff help!!)
Auburn: https://www.thirdgen.org/forums/tr...ing-axles.html (Tips/Tricks for Installing Axles, Bearings, Seals)
*Apparently, G80 was an extra-cost option which could be special ordered on any rear regardless of ratio.
**The most reliable way to determine if your car is equipped with a limited slip is to look. That said, this from big gear head: With the tires off the ground and the transmission in neutral, you should be able to turn one wheel and the other will follow in the same direction. This is limited slip or "posi". If the wheels turn in opposite directions, it’s a standard/open differential—OR a worn out limited slip.
JamesC
Old Apr 26, 2010 | 09:34 AM
88gta3508's Avatar
Engine: 231 / 383
JamesC
the method I supplied.. is straight from the GM manual 48 LBS or less it's worn OUT>>>>> one wheel locked...one wheel free if it's limited slip = (POSI)
Old Aug 1, 2011 | 11:18 AM
JamesC's Avatar
At this late date, hopefully the OP has found the answer to his question.
JamesC
Old Aug 5, 2011 | 05:25 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Watch the movie "My cousin Vinnie" They explain the posi function very well for a movie.
Old Aug 10, 2011 | 12:02 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
Reddeath210
Oct 6, 2015 08:20 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
