Transmission Problem?
Old Apr 26, 2010 | 11:00 AM
Shane4524's Avatar
Car: 1986 Camaro IROC Z28
Engine: 5.0L 305 TPI
I have a slight issue. I am not sure if it is exactly a transmission issue so I am going to just explain it and see what you all think.
This normally happens in overdrive but sometimes in 3rd and it's not often it's a once in a while thing period. But, it happens and I dont' like it. When accelerating at most intensities from slow to fast the car will tend to jerk a little bit. It's not extremely noticable, but I notice it while driving. What could teh problem be?
Old Apr 27, 2010 | 01:06 AM
bjm1206's Avatar
Re: Transmission Problem?
check your motor/tranny mounts, most likely what it is I had the same problem
Old Apr 27, 2010 | 10:13 AM
Shane4524's Avatar
What do I check on them? Make sure they secure or what?
Old Apr 27, 2010 | 02:36 PM
94_LT1_Z's Avatar
Yeah just make sure the rubber isn't shredded and that the mount is generally in tact. My 94 would easily break a brand new stock tranny mount on a single full throttle 1-2 shift. Stock GM tranny mounts are pretty flimsy IMO. I had to go with a poly mount,
Old Apr 28, 2010 | 08:34 PM
bjm1206's Avatar
U just visualy inspect them find a spot on your motor you can use a pry bar try prying the motor up if it moves in exess than you need new ones I agree with 94_lt1_z when you replace them use poly ones they are much stronger and dont cost much more.
Old Apr 29, 2010 | 07:49 AM
Shane4524's Avatar
Ok, Thanks!
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
