Thoughts and advice on Z-28 rear
Old Apr 29, 2010 | 08:16 PM
White92RSVert's Avatar
Hey all,
I have drums on the rear of my 92 vert. I came across a Z-28 in a yard with discs. Do you think it's worth pulling the whole rear-end and swapping out? Is there an easier route to get to disc brakes on the rear?
Old Apr 29, 2010 | 11:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Thoughts and advice on Z-28 rear
What year is the Z28 diff? You already have the best factory diff possible under your car. If the Z28 is older than 1990, you're downgrading. If the Z28 disk brakes are on a 9 bolt diff, they don't easily adapt to your 10 bolt. The housing mounts are different.
If you want to convert drum to disk, your best option is to spend a few bucks on an aftermarket disk brake kit. It will be far better than a factory system.
If you don't need or want a parking brake, you can look at the sticky in the brake forum that I wrote up about putting disk brakes on any diff. I fabricated and installed some GMC Jimmy PBR rear brakes on my 9" diff for around $200. The same principal can be applied to any diff if you have even a little bit of fabrication skills.
Old Apr 30, 2010 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
With the following kit and the second-design combination valve, you should be good to go:
http://www.flynbye.com/catalog/i30.html
My 'guess' is that you'll need the second-design parking brake cables as well.
JamesC
Old Apr 30, 2010 | 07:42 AM
Thanks guys. Great advice as always. I'll take a look at the aftermarket discs. One thing I do want to keep is the e-brake. Even though I have an auto, I always use the e-brake when parked. Don't like rocking the tranny.
Hey all,
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
E Rod
Aug 28, 2015 05:17 AM
justin57
Aug 20, 2015 07:05 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
