what to do with the tranny cooler lines and question about torque arm mount
Old May 3, 2010 | 01:11 AM
305blackbird's Avatar
Car: 1987 pontiac Trans Am
Engine: 1988 305 TPI
Axle/Gears: 2:73 ... I think
im almost done my 700r4 to 5sp swap but i have 3 problems what do i do with the tranny cooler lines do i have to remove them and buy a plug or what? also do u HAVE to use a torque arm mount from a manual or can u modify it to fit the t5 and would it be horrible to drive without the torque arm for a day or two. and lastly the biggest head scratcher is the clutch and brake pedal are bolted up and everything tight but the clutch and brake pedal both sway side to side about a inch. what the hell can i do to fix this i was thinking about putting some kind of shim up there any ideas? thanks for the help
Old May 3, 2010 | 07:48 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: what to do with the tranny cooler lines and question about torque arm mount
Do NOT drive without the torque arm mounted.
Old May 3, 2010 | 08:09 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
You will never make it out of your garage without the torque arm mounted. The rear axle will flip backwards and the stress on the driveshaft (the only thing that will hold from completely flipping backwards) will be under such stress the car wont move. You have to have the torque arm.
As far as the tranny cooler lines, just take them out. You shouldnt have to plug the holes in the radiator though it may be a good idea just to keep junk out just incase the radiator ever gets used in an auto car again. You may also have stuff drip out for a day or two if you dont plug it.
As far as the pedals moving side to side, just try tightening up the long bolt that holds everything together. The pedals I got were the same way and tightening helps a little. But mine too have about the same amount of play.
84z96L31vortec
Aug 20, 2017 12:16 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
TreDeClaw
Aug 14, 2015 06:58 PM
