can someone identify this diff?
Old May 4, 2010 | 07:58 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Just picked up this diff with a set of 3.73's today, the seller wasn't sure if it was a stock unit or not.
Thanks for any info.
Old May 4, 2010 | 08:09 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: can someone identify this diff?
it's appears to be a stock older gen Posi from around 1983
the weak point is that bracket that holds the 4 spings in place
they usually crack.. and the spring!! will find a new home in between the ring and pinion
that's what happen with my first 83 TA
Old May 5, 2010 | 08:51 AM
big gear head's Avatar
That is the older Auburn. They aren't made that way anymore.
Old May 5, 2010 | 11:54 AM
Engine: 450HP 355
Transmission: TH350
Cool, Thanks guys.
It came with a set of Richmond 3.73's with very low miles. I'm sure it'll be fine for what i'm going to do.
Old May 5, 2010 | 12:15 PM
You might want to see if it's worn out before you go to the trouble of installing it.
Old May 5, 2010 | 12:20 PM
Engine: 450HP 355
Transmission: TH350
Judging by the rear tires that i bought from the old owner it should be working pretty good.. haha
I'll have it all checked out before it goes in. thanks for the heads up.
Numbah-1
Oct 2, 2015 08:27 AM
Vincent135
Sep 28, 2015 10:50 PM
