Can somesome take a look at my contact pattern?
Old May 8, 2010 | 08:53 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Can someone with experience with setting these up let me know what ya think? This is my first setup and not entirely sure what optimum looks like. I haven't just slapped it together and this is what I got, been messing with it for a few days, (been busy), and this is what I've got so far. They're Richmond 3.73's with a BL of .014. I've tried to get it tighter, like around .009-.012, but haven't been able to without over shooting and making it too tight.
Attached Thumbnails Can somesome take a look at my contact pattern?-img_1071.jpg   Can somesome take a look at my contact pattern?-img_1073.jpg
Old May 8, 2010 | 09:23 PM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Re: Can somesome take a look at my contact pattern?
Looks ok to me back lash should be OK I'm sure some one with a little more experience will chime in tho
Old May 8, 2010 | 11:08 PM
big gear head's Avatar
The pinion is too deep. Use a pinion shim that is about .005 thinner and try again. Be sure to set the pinion bearing preload the same each time and get the backlash right. If Richmond says to set it at .007 to .009 then set it there.
Old May 8, 2010 | 11:36 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Ok noted, I already lowered it once already cause it was even deeper the first time. But I did read though, that Richmonds like to be a little on the deep side and therefore toe heavy, (towards center of ring). Supposedly it adds to the strength a little bit, but sacrifices some noise? It even looks like in there illustrations, their "ok" patteren even looks toe heavy.
Old May 9, 2010 | 12:45 PM
MPIpowered4x4's Avatar
richmonds are known to make noise with a perfect pattern. i dont know why, I have heard set them a lil loose, then when the rear end warms up, the gears will get tighter and the noise will quit. Im by no means an expert, but if anybody else has an opinion on this, lets hear it.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
indygene
Sep 26, 2015 11:21 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
dimented24x7
Sep 17, 2015 06:58 AM
