need help with speedo gears
Old May 10, 2010 | 12:34 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i have an 87 iroc with a t5 out of a later year camaro. well the mecanical gear i have on it now has a metal rod with the gear that slips right on the end.It in NOT the one peice gear shaft style one. where do i buy different gears from and how do i know which ones to buy because they only say gear through gms websit with no pic or description.
Old May 10, 2010 | 12:49 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: need help with speedo gears
i believe it was a 90camaro. also it has the smaller style vss in it. im really lost guys it says im going way faster then i am please help me.
Old May 10, 2010 | 03:08 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
go to your local gm dealer thery might be able to help ya tell what year the tranny is and what rear end gears you have they should be able to tell you what colors you need and any info on the tranny id number or such
Old May 10, 2010 | 05:07 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
What tire size and rear gear are you running?
The new sleeves have a seal that is left in position for the longer length shaft gears or pushed further in for the shorter length shaft gears.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
