Delete
Old May 12, 2010 | 12:33 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Delete
Help! No one around me carries them and I need em ASAP!
Old May 12, 2010 | 12:37 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Need help ASAP. Would grade 8 bolt work for flywheel to crank?
you dont have any major part stores around? not even and AutoZone
Old May 12, 2010 | 01:52 PM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
yes grade 8 will work just fine.. stronger too! I have them in mine
Old May 12, 2010 | 02:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
flywheel to crank, NO!!!!!!
regular hex bolt heads are usually too thick and will interfere with the clutch.
Old May 12, 2010 | 02:12 PM
Nater36's Avatar
the bolts looked exactly the same and were exactly the same size...
Old May 12, 2010 | 04:52 PM
JTNKTZ's Avatar
Engine: 355/350
I ended up finding some at Carquest. Everywhere else didn't have them in stock. Not that it matters anymore considering my flywheel is for a 2 pc rms not a 1pc rms......
So now I have to wait for a new flywheel.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
