B&M Ratchet Shifter problem or something else?
Old May 7, 2010 | 03:43 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
I had my trans rebuilt last summer and got a 600hp kit from Danna Pro built. I also use a B&M Ratchet Shifter, and never had problems before with it. After doing alot of work to the car over the Winter and early Spring I finally got it on the road. The car seems to shift well when in Drive, just cruising or stomping on the pedal. But when I try to use the Ratchet shift starting in 1st, then go to second it will shift into second for a little bit. But then it will actually drop it back into first. If I also manually/ratchet shift 1st, 2nd, 3rd it will still downshift back into first. (You talk about a scary situation I actually thought I was going to blow something up) This has happen a couple of times since by just experimenting at 5-10 MPH to see if it was just me or what. When this happens I have to come to a complete stop and get it out of ratchet shift mode. Which I have found then its best to put into Park, and then back into Drive. I have had someone shift for me while on jack stands, engine off and I'm underneath to make sure it does shift correctly visually at the trans. I also made sure the cable is not binding. I have also thought it could be the TV cable, although I'm sure I set it right. As I said before in Drive it seems to shift fine through all the gears, in any driving situation.
Old May 8, 2010 | 02:52 PM
Car: 1988 IROC-Z28
Re: B&M Ratchet Shifter problem or something else?
Anyone have similar problems or ideas of what it could be?
Old May 11, 2010 | 03:29 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Which shifter? Are you sure the cable is adjusted right?
Old May 11, 2010 | 08:33 PM
Car: 1988 IROC-Z28
Thanks for replying!
Its a B&M Mega Ratchet Shifter, and I think its adjusted correctly, but if its not then, I guess thats why I'm having the problem? Although it does seem to shift fine through all the gears when its shut off.
Old May 11, 2010 | 08:55 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
It sure sounds like the shifter cable needs to be adjusted(Like it's almost between 2 gears) Good luck.
Mark.
Old May 11, 2010 | 08:58 PM
Car: 1988 IROC-Z28
WERID!?!?
I've never heard of anything like that. Should I just try to re-adjust, or is there something I can do to check and verify?
Old May 11, 2010 | 09:03 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
That's what I would do before I tried anything else.
Mark.
Old May 11, 2010 | 09:07 PM
Car: 1988 IROC-Z28
Ok!
strange that its ok though when I leave it drive.
Old May 11, 2010 | 09:12 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Yea but that's why I think it's not adjusted right. It's like it's between 2 gears but when it's in drive your not really messing with the shifter.
But I could be wrong.
Mark.
Old May 11, 2010 | 09:14 PM
blue85305's Avatar
Car: 1984 camaro
Axle/Gears: 3:42
Id run through the adjustment again just to be sure. It took about an hour to get my cable adjusted correctly, so that's where I would start. You also need to verify that you're using the correct hole in the gear selector arm.
Old May 11, 2010 | 09:15 PM
Car: 1988 IROC-Z28
Thanks!
Although I'm not really sure where to start, as far as re-adjusting it?!?!
Old May 11, 2010 | 09:17 PM
Car: 1988 IROC-Z28
I did check that when I crawled under neath the last time.
Old May 11, 2010 | 11:11 PM
blue85305's Avatar
Car: 1984 camaro
Axle/Gears: 3:42
do you still have the instructions they run through how to adjust the cable. if not here's the link.
http://www.bmracing.com/bmracing/ins...truction/8.pdf
Old May 12, 2010 | 05:34 PM
Car: 1988 IROC-Z28
Awsome!
BewleyBizzIROC
Feb 3, 2020 09:52 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
