What did my trans rebuilder mess up?
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
86 700r4. Pro Built rebuild kit from Dana. Street/strip kit.
Finally got everything in the car last night. Got everything adjusted, fired it up. Got up to where the fluid level looks right (about 8-9 qts. 10" converter)
Car is still on jackstands. Started to go through the gears, First gear is all I have. Car doesnt even feel like it wants to go into reverse. Even undone the shifter and manually shifted the car from underneath into reverse. Nothing.
Put the car in drive, only has 1st gear. Nothing else.
What did my rebuilder do wrong?
Thanks guys. In hind sight I should have just bought a transmission from Dana.
Car: 88 IROC
Re: What did my trans rebuilder mess up?
Just spoke with Dana. He said one problem could be if my builder switched front pumps without blocking a certain passage. He seen that 11 years ago where it only gave him one gear.
Got plans for this weekend, so it looks like next weekend I'll be pulling my transmission back out.
Anybody else got any ideas? I think he just completely messed something up.
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Is the TV cable adjust right? When we first put a 700R4 in my brothers truck we didnt have the cable adjust right and he only had 1st. We just made a small adjustment, and it shifted ok.
Car: 88 IROC
After I had some time to think about it, I think I am too loose.
I dont remember if it was too loose or too tight. We did have reverse though.
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Even with my tv cable completely disconnected I had all of my gears including reverse. When that little plastic peice broke that connects the cable to the hook on the TB it goes onto I had to drive it about 20 miles home, and I couldn't do anything until I got home so I would know. It just shifts really hard and really fast when theres no TV.
Car: 88 IROC
yeah Im pretty sure its something else. Not looking forward to this weekend. I reckon I will be dropping the pan friday evening and draining as much out as I can. I hate having to drain good fluid. Always going to be some that gets on the floor and is wasted. Sucks at $7.50 a quart.
Car: 88 IROC
Found the problem. PR valve clip wasnt seated properly and it fell out. Reinstalled it last night with a new clip and everything is right.
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
That happened to me, dropped the pan, and there it was..
Mine was also stuck in Drive, the shifter linkage inside the tranny came apart.. Sucked..
Car: 83 Z28, 88 Iroc
Engine: 305 CFI, 350 TPI
Transmission: 700R4, 700R4
Glad you solved your issue so fast! Hope it shifts good for a long time coming.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
