bent shifting fork???
Old May 18, 2010 | 07:17 PM
555's Avatar
555
Car: 90 Z28, 74 Scout II
Engine: healthy 355
Transmission: t-5
Axle/Gears: 4th gen 10 bolt 3.23
Any ideas: did a t-5 swap and from the start it had a problem going into first. Now I'm to the point it won't hold at all it just pops out (almost feels and sounds like the teeth don't engage, just grazes off), if I downshift it will hold until I start to coast then falls right out. I know t-5s are way under built, I just want to get to cruising before I upgrade later this year....
Old May 18, 2010 | 08:18 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: bent shifting fork???
If its popping out of gear, its probably a syncro. The T56 I bought for my swap had no 2nd gear. I was told that you could force it into 2nd, but it would pop out. This is what I found when I got it apart.
Old May 24, 2010 | 05:56 PM
555's Avatar
555
Engine: healthy 355
Transmission: t-5
pullin the tranny in the next week or two, so I'll be looking for a broken syncro, thanks. P.s. your marrow is lookin good buddy!
Old May 24, 2010 | 10:51 PM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
I had the exact same problem the little teeth on first gear were worn and the gear had to be replaced
Old May 26, 2010 | 08:19 PM
555's Avatar
555
Engine: healthy 355
Transmission: t-5
I'm gonna get it ripped apart this weekend I think, I'll keep my eyes open, thanks.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Zell1luk
Sep 29, 2015 10:36 AM
