TV Cable Issue
Old May 22, 2010 | 02:40 PM
dippin88's Avatar
Car: 1988 Camaro sports coupe
TV Cable Issue
question guys how do I adjust my tv cable on my 89 iroc 5.7 TPI
Old May 22, 2010 | 02:45 PM
kjvail1204's Avatar
Re: TV Cable Issue
There is a little metal tab on the inside of the TV cable just past where it locks into your TBI bracket. Push it in and slide it forward, its only going to take little movements, you can just drive down a road and notice when the sifts happen pull over and adjust it a little at a time till you get it right.
Old May 22, 2010 | 02:47 PM
kjvail1204's Avatar
Re: TV Cable Issue
http://www.google.com/imgres?imgurl=...IsOC8gbGuPXDCg
Old May 22, 2010 | 04:23 PM
dippin88's Avatar
Re: TV Cable Issue
I have a TPI not TBI but is it the same ****...
Old May 22, 2010 | 04:52 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: TV Cable Issue
Um, no. Read the article that goes along with the pic you posted. That's the correct way.
Old May 22, 2010 | 11:18 PM
dippin88's Avatar
Re: TV Cable Issue
so does this work on TPI???
Old May 23, 2010 | 09:19 PM
watajob's Avatar
Car: 92 T/A 'vert
Re: TV Cable Issue
Works on any 700R4 or 200-4R, regardless of induction style.
kjvail1204's Avatar
Re: TV Cable Issue
As far as I know its the same thing for both cars take a took on the motor, you should see the trottle cable and the Tv cable
Old May 23, 2010 | 09:21 PM
kjvail1204's Avatar
Re: TV Cable Issue
http://www.chevyhiperformance.com/te...ble/index.html
its the same thing but here is the correct one for your car
Old May 23, 2010 | 11:51 PM
dv8's Avatar
dv8
Car: 88 IrocZ Vert
Engine: 5.0 TPI
Re: TV Cable Issue
I'm having an issue with the TV cable. The car wasn't downshifting properly and when i tried adjusting it I pushed the cable all the way in and when i rotate the throttle all the way forward the cable doesn't adjust out. any ideas?? dont mean to hijack the thread just figured it was a good place for the question...
Old May 24, 2010 | 09:47 AM
kjvail1204's Avatar
Re: TV Cable Issue
You can just pull it back out if its nots pulling out its self some times one or two notches is al lit take to make the difference, I would recomemend that after you get it adjusted you mark it some how so if you have to move it later you can get it right back
Old May 26, 2010 | 02:23 PM
kjvail1204's Avatar
Re: TV Cable Issue
Any luck??
Old May 26, 2010 | 08:08 PM
dv8's Avatar
dv8
Car: 88 IrocZ Vert
Engine: 5.0 TPI
Re: TV Cable Issue
Thanks.. It seems to be running much better. will still tweak it a bit. I appreciate your help!
Old May 26, 2010 | 08:29 PM
kjvail1204's Avatar
Re: TV Cable Issue
No problem
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
greenyone
Sep 2, 2015 03:39 PM
