I hear a noise...
Old May 18, 2010 | 08:42 PM
92yellowcamaro's Avatar
Car: 1992 camaro rs, 1988 saab 900
Engine: 305 tbi 5.0L V8
I hear a noise...
Hey all,
2 week ago i swapped out my rear for a posi. yesterday got my brake lines in for it (ones on the rear leaked) put them on tonight and bled the system. car stops fine takes off fine... i do notice a little humming noise from the rear, when i step on the brake it quiets down then when letting of the brake and just cursing it picks back up, when on the gas picking up speed i dont notice it to much. thinking its just the shoes rubbing on the drums.
the gears and all look great, their was no metal shavings or anything when i got it so i dont really think its the gears.
as i said before i think its the shoes rubbing or now as i write this could it be the axle bearings.....
any pointers?
Old May 18, 2010 | 09:54 PM
vanimal's Avatar
Re: I hear a noise...
wheel bearings are a strong possibility. The brakes might be changing the load on the bearings, quieting them down. Just did the ones in my van, made quite the difference.
Old May 18, 2010 | 10:06 PM
thanks for the input, guess if i "check" the bearings that will involve replacing them if i have to pull the axles, so hope its just the new brake parts... thanks
Old May 18, 2010 | 10:21 PM
vanimal's Avatar
it's a fairly cheap and easy job, plus you get to change the fluid, which isnt a bad thing. It took me like 30 minutes to do the ones on my van, but then again it doesnt have a LSD/posi/locker, or whatever you Chevy guys call it (limited slip differential for Fords).
You dont want to wait too long because it will damage your axles eventually. An easy way to tell is to check for excessive play (up and down) in the hub when you pull the wheel off. It should be pretty tight.
Old May 18, 2010 | 10:27 PM
got new fluid in it, didn't notice much play in the hubs... still should check again before lots of driving on it. not my dd so i dont use it as much but still do drive it when nice.
again thanks for your input
Old May 19, 2010 | 07:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Often when the bearings are shot, you'll see weeping from the axle tubes. Here's a how-to, if need be:
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
Old May 19, 2010 | 07:23 AM
big gear head's Avatar
You don't have to replace the bearings to check them. All you have to do is remove the axles and inspect the area where the bearing runs on it. If the axles show signs of wear then you need to replace the bearings and axles.
Old May 19, 2010 | 09:36 AM
vanimal's Avatar
i figured he ment that if he went through the trouble of pulling the axles, he should just go ahead and spend the $30 to change the bearings.
Also, i dont know how good they are, but they have repair bearings that ride on a slightly different part of the axle in case it is worn. I have them in my van right now actually, even though the axles were good (it's just all they had at the store).
Old May 19, 2010 | 10:21 AM
Those repair bearings usually cause more trouble than they fix. Thel usually leak oil all over the brakes and they are very hard to remove when you get ready to fix it the right way.
Old May 19, 2010 | 06:39 PM
That's what i was getting at, if im going to take the axle out might as well replace them....
So i just took the car for a spin, the noise quieted down while picking up speed and around 50-60 i dont hear anything at all, but when slowing down at around maybe 10-5mph i notice the sound a little bit. then when on the gas picking up speed its got little to no noise. i did go around a few corners hard and did hear it but then it stopped after the harsh cornering. yeaaa....
Old May 20, 2010 | 08:56 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
check the pinion, mine started whining and the nut was backing off. you'd have to remove the driveshaft and check for play there.
Old May 23, 2010 | 09:27 PM
checked everything over again and it was the brake shoes, weren't adjusted right and were making the noise that i was hearing, again thanks everyone
Falcon50
Aug 22, 2020 03:26 PM
92projectcamaro
Dec 8, 2015 12:25 AM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
thejimsterz28
Sep 30, 2015 08:52 PM
