700R4 not shifting when cold
Old May 23, 2010 | 09:59 PM
KARR81's Avatar
Car: 1983 Firebird Trans Am
Engine: 1969 Chevy 350 crossfire FI
Transmission: 700R4 overdrive auto
Axle/Gears: Posi Rear
Will not shift into 2nd gear when the tranny (700R4 OD) is cold. Once it warms up, the throttle valve doesnt seem to stick anymore. I put some lucas additive in there, and still no dice. The fluid is clean (ive only put 500 miles since the last fluid/filter change). The engine was swapped from the stock 305 to a 350 from a 1969 chevy C10 pickup. The 350 has more than double the output than the measly 165 hp 305. Would this cause stress on the valve body or transmission that was meant for the lower hp engine?
Old May 23, 2010 | 10:02 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 700R4 not shifting when cold
likely a broke accumulator spring.
92firebirdguy
Sep 1, 2016 07:53 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TheTraut88
Sep 7, 2015 05:22 PM
