LT1 flywheel help!!
Old May 24, 2010 | 05:04 PM
bowtiedad_z28's Avatar
LT1 flywheel help!!
We are doing a T56 swap into a 87. Putting it behind a Ramjet 350. It already has a one peice rear main seal. What de i have to do to the LT1 flywheel for balancing purposes?
Old May 25, 2010 | 09:26 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: LT1 flywheel help!!
if it's one piece should bolt right on the ram jet its internally balanced from gm i think
Old May 25, 2010 | 09:47 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
You should find out if it is internally balanced, then if it is your going to have to get your flywheel neutral ballanced.
Old May 25, 2010 | 01:53 PM
Thanks for your help guys. Yep i did find out it is internally balanced and the flywheel is a neutral balanced new GM lt1 flywheel.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
