4.10 gears what mph ?
Old May 21, 2010 | 04:38 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I finally fixed my speedo cable after 4 years. And now i have a 4.10 gear and a 275-60-15 tire. Just wondering if anyone would know how much the speedo would be off ? Car can stock with 3.23 gears if it helps any.
Old May 21, 2010 | 04:59 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: 4.10 gears what mph ?
probably around 15-35mph higher starting at 15mph actual speed.
Faster you go the higher it is off.
Pace someone or use a GPS to get a reading at 55mph so you can at least know the speed on your cluster at that actual MPH, this way if you are the only car on the road you won't be going to fast or too slow and get pulled.
Old May 21, 2010 | 05:12 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Good Idea.
Old May 21, 2010 | 05:37 PM
Guest
Guest
Posts: n/a
If I correctly understood that sticky on how to figure it, you just need a 15 tooth drive gear, and a 44 tooth driven gear. That other sticky seems to have all the necessary GM part numbers.
Old May 21, 2010 | 08:55 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
You can use these calculators to find out what rpm you would have been at stock vs. what your at now.
http://www.fbody.com/calc.htm
Old May 22, 2010 | 05:01 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
this is the place it has all your speedo gear needs.
fast shipping also
http://www.transmissioncenter.net/sp...__va.htm#700r4
Old May 23, 2010 | 06:17 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
how much of pita is it to change speedo gears ?
Old May 24, 2010 | 02:19 AM
even if you have never done it..it's a piece of Cake.
will take you about 45 min with hand tools.
thats including getting the car on Jack stands
it's easy
Old May 25, 2010 | 02:03 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Well i took my GPS with me for a ride. Weird thing is my speedo is only about 5 mph off. I think the taller tires helped a little bit with that.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
GouldyGTR
Sep 7, 2015 09:05 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
