t5 help very odd?
Old May 24, 2010 | 09:30 PM
maccladehup's Avatar
Car: 1989 iroc z
Engine: 355 vortec hotcam tpi
Transmission: t-5
t5 help very odd?
when i have the clutch pushed in and stick in neutral and rev the gas to much 3000 rpm's or so i get a grinding noise let the clutch out and it stops. any idea whats wrong
Old May 25, 2010 | 07:49 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: t5 help very odd?
clutch throw out bearing . time for a new clutch , pressure plate , pilot bearing & throw out bearing . normally all parts ( stock ) , come as a kit . just did mine a month ago . not a bad job , but not easy . be sure to inspect flywheel & re-surface it . good luck .
Old May 25, 2010 | 09:45 AM
Car: 1989 iroc z
Transmission: t-5
When you say resurface flywheel. Sand it? Or do I have to take it in to get resurfaced?
Mark_ZZ3
May 24, 2018 01:02 PM
Stryker412
Sep 20, 2015 06:59 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Warlocksirix
Sep 3, 2015 12:26 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
