Speedometer gear swap 2.73 to 3.23
Old May 28, 2010 | 12:11 AM
Steve 92 RS's Avatar
Car: 92 Camaro RS w/ heritage package
Engine: 305 v8 5.0 TBI
Axle/Gears: TrueTrac 3.23
I just changed my rear end from a 2.73 to a 3.23 and I'm having trouble finding which driven speedometer gear to be used in the rear end change. I was informed to get the brown gear (25513046) for this swap but after installing the new brown gear my speedometer now reads approximately 5 higher than my actual speed when going say 45 (at 45 actual speed my speedometer reads 50). Does anybody know which driven gear to use with a 3.23 rear end? Please help!
Old May 28, 2010 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer gear swap 2.73 to 3.23
You might, if you haven't, check the stickies at the top of the page. In a T-5 swap of the above ratios, you'd have to swap both the drive and driven gears.
JamesC
Old May 28, 2010 | 05:31 PM
Thank you
Old May 28, 2010 | 07:01 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
If th700r4, yours should have a red drive gear and a "blueish greenish" driven gear (38 teeth?). In wich case you need the grey (44 teeth?).
Not 100% sure the exact number of toots anymore, but I have done it twice and used the grey driven gear from http://www.transmissioncenter.net/sp...0gear%20driven
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
