stumped on what gears are in my car...
Old Jun 4, 2010 | 06:49 AM
thewhitestripes's Avatar
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
i have a 1988 305 iroc with a 5speed trans. i want to upgrade my gears but i need to kno what my original gears are so i can decide whats best for me. would anyone know the original gears in my car? ive done a search and i found a lot on gears but i couldnt find the original gears for my exact car.
Old Jun 4, 2010 | 07:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: stumped on what gears are in my car...
If original:
https://www.thirdgen.org/1988-chevy-camaro
If not (who knows if the rear end is original) and it's a 10-bolt:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jun 4, 2010 | 07:36 AM
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
so according to that first link (the second one wouldnt load cause im on a P.O.S. school computer) i either have a 3.08 or a 3.45? also, i forgot to mention i have a 10 bolt rear so im assuming its a 3.45
Old Jun 4, 2010 | 07:38 AM
JamesC's Avatar
3.45 is a 9-bolt.
JamesC
Old Jun 4, 2010 | 11:14 AM
shawty82's Avatar
Car: 1991 camaro rs
hes right that is a 9 bold u either have 2.73 , 3.23 or 3.73 gears for stock ten bolt for a camaro im pretty sure correct me if im wrong
Last edited by shawty82; Jun 4, 2010 at 11:15 AM. Reason: accidently posted the reply without knowing
Old Jun 7, 2010 | 08:40 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Take off the cover and turn the ring gear untill you see a set of numbers stamped into it... will look something like '41:12' or something like that. Thats the number of teeth on the ring and pinion gears. Do the math and it will tell you the ratio. Then you know for sure.
Old Jun 7, 2010 | 09:09 PM
JamesC's Avatar
The 10-bolt FAQ above provides the numbers for the different ratios.
JamesC
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
