Broken transmission or u joints
So I checked why my driveshaft is vibrating and the back of the transmission slip yoke is making a metalic sound while i move it back and forth and I could be wrong because the front u joints are behind it.
How do I fix this and is it possible to break a slip yoke?
The front of the driveshaft moves about half an inch and all I hear is metal on metal banging like someone too a hammer to front of the driveshaft. But the front defently moves more then the rear. Its a good car verything works besides that.
Thinking about selling it for 3000 or so
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Broken transmission or u joints
the trans yoke is moving a half inch, or the driveshaft yoke is moving? sounds like a u-joint. I cant see how the treans yoke could move that much and the car still be drivable.
fix? have the u-joints (front and rear) replaced
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
take the driveshaft out and check the joints this was you can see whats moving around in there
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
