Pro's, and Con's
Old Jun 11, 2010 | 07:13 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Pro's, and Con's
Of using the AC condenser for a tranny cooler.....Opinions please...I did this on my last 700r4 Camaro, and it seemed to do fine, Just rebuilt the tranny, and put in a 2400 stall....
Pros'
It is free
It is already there
It is big
What are the cons, Thank you very much, Tom Shaw
Old Jun 11, 2010 | 08:03 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Pro's, and Con's
Not sure if having the AC oil going through the trans is good.
Old Jun 11, 2010 | 08:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I would hope its cleaned first
Old Jun 11, 2010 | 08:29 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
It will be taken out, and cleaned...No chance of contaminates, then after it is run a few more days, I am going to change the fluid again, since the tranny is new.... Thank you very much for your replys...BTW, I am changing the radiator at the same time, just to be sure the cooling system is in perfect shape..If anyone needs the old one they are welcome to it, it is good...Any more thoughts on this subject????
Old Jun 12, 2010 | 12:52 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its been done since way back in the day, the only problem is if the trans run to cool, not sure on the temp range but know its why its runs through the radiator stock, the hot coolant is colder then the trans fluid, cooling it enough in a stock situation.
probably search trans temp gauge threads for a proper range to be in.
I should know as I run a extra trans cooler but its about the size of a small note book so Im not worried about running to cool
F.I. 57 Belair
Aug 23, 2021 01:09 AM
tmellott89
Oct 14, 2015 02:06 PM
djmarch
Oct 2, 2015 10:41 PM
3.8TransAM
Sep 17, 2015 02:16 PM
scotrans am
Sep 5, 2015 04:26 AM
