i need some help with a 700r4
Old Jun 15, 2010 | 10:48 PM
jake1992jake's Avatar
Car: 1989 camaro rs
Engine: 406 chevy
Transmission: turbo 350
Axle/Gears: 3:73 posi
my new 700r4 will not hold a gear it always shifts at a certain rpm wen i put it in first and do a burn out it will go right through da gears........how can i get it 2 stop with out buying a kit 4 it????????????????????????????
Old Jun 16, 2010 | 06:30 AM
Pro Built Automatics's Avatar
Re: i need some help with a 700r4
All "stock" 700R4's will come out 1st gear if held past governor shift point. To fix this you will need the TransGo Performance Shift kit (700-2-3). I carry the modified version of this Shift kit. This kit will allow you to hold 1st gear to any rpm, until you move the shift lever.
Old Jun 21, 2010 | 08:57 PM
Car: 1989 camaro rs
Engine: 406 chevy
it has a strip shift kit already what else is there
Old Jun 22, 2010 | 03:47 AM
You don't have the Shift kit I described. What brand valve body kit do you have?
Old Jun 27, 2010 | 09:59 PM
Car: 1989 camaro rs
Engine: 406 chevy
like i said its in a v8 s10 i bought it has a 700r4 when it shifts into gears it shifts hard!!!!!!!!!! TCI Auto 376600 - TCI 2004R/700R4 Lock-Up Wiring Kits
http://www.summitracing.com/parts/TCI-376600/
is this what i need 2 hold the gears
Old Jun 28, 2010 | 02:36 PM
No, this is for the lockup only. If you have the TCI valve body kit, it will hit hard on the 1-2 shift (this is not what you want, you need to tone it down), but will not hold 1st gear. The TransGo Performance Shift kit is the only one that will do this.
Old Jun 28, 2010 | 03:10 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
I have had the TCI kit in before and hated it. it didn't hold the gears as well and the slam shifting got old very fast.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
