Gasket Sealer
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
Gasket Sealer
A simple question but I can do without the leaks and I wanted to know what others have done. I'm changing the pan gasket and filter on a 700r4 mostly because it's already leaking. Kit comes with a rubber gasket. Do I smear extra extra gasket sealer like blue perma on both sides of the gasket or will that just make it worse?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Gasket Sealer
if its a rubber gasket, i would not put sealer on it. if its a paper type gasket, then yes.
or i suppose you could just say screw the gasket and just RTX the thing right on. let it cure 24hours before final torque and adding fluid though
