Help!! T56 swap issue
Old Jun 19, 2010 | 05:56 PM
bowtiedad_z28's Avatar
Ok the swap went in perfectly from the 4th gen pedals to the brand new pre-bled GM hydrolics. The t56 is in perfect working order. Brand new throwout bearing, brand new GM flywheel, GM clutch ,GM Pressure plate. The issue we are having is the pressure plate is not releasing from the clutch enough to be able to get it in gear while running or starting it in gear without the car wanting to roll. It is just plain not disingaging all the way. Any ideas would be helpful.
Old Jun 19, 2010 | 10:30 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Help!! T56 swap issue
i had that problem i bent the rod in the slave so i cut alitle bit off of it and rewelded it back together mine didnt seem to release all the way and that was the problem
Old Jun 20, 2010 | 11:29 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I know you bought pre bled hydraulics, but its still possible there is air in there. The factory doesnt get everything right all the time.
Old Jun 20, 2010 | 05:52 PM
Our problem is solved. DO NOT use the torque specs out of the Haynes repair manual for the pressure plate bolts. They will be to loose and cause this symtom. Use GM's torque specs of 22lb's. Our problem is fixed.
Old Nov 29, 2010 | 01:52 PM
IROCUDREW's Avatar
Car: 1989 Chevorolet Iroc-z convertible
Engine: 383, holley terminator efi
Axle/Gears: stock 10 bolt w/ 3.73
I have a question; How did you install the 4th gen pedals did you cut off the accelerator pedal bracket from the brake/clutch one? I am going to install the pedals and want to know of i use the gas pedal or not. Any help would be awesome.
Old Nov 29, 2010 | 01:59 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
I used the factory pedal and cut off the 4th gen pedal
Old Nov 29, 2010 | 08:04 PM
I used the whole 4thgen brake, clutch and gas pedal. I did no cutting or splicing of the pedals. As far as that goes, i thought it was a easy swap.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
