Howling 9 bolt axle need help.
Old Jun 27, 2010 | 09:16 PM
marks88gta's Avatar
I havent had this car long. The rear axle howls when under power and stops when you let off the gas. I thought it was the gears maybe it is, The backlash between the pinion and ring gear was excessive so I shimmed it to spec. It made no difference so I am asking for help. Thanks
Old Jun 27, 2010 | 09:54 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Howling 9 bolt axle need help.
I would have thought low fluid, then bearings // seals, then just worn out.
Old Jul 2, 2010 | 03:39 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
time to trash it.
swap in a 10 bolt.
parts are cheaper and easier to find
the posi cones eat up the carrier and fill the rear with metal.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
billybob6110
Sep 23, 2015 01:30 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
red90IROCls1
Aug 25, 2015 06:56 AM
